Been struggling to get the drive shaft out of one of my trailing arms, so applied a little heat while in a press. Shaft came out OK at 12.5 tons!
Underneath the hub on the trailing arm is a rubber bung, which got a bit warm during the process and is no longer fit for purpose. Does anyone have any idea the BMW code for these, if one even exists? The hole diameter is circa 10mm
Many thanks
Many thanks
