Rear subframe threaded bolts
Roman
Hello, after 20 years I've decided to restore the rusty chassis on my z3, and I was wondering if anybody know how to remove the threaded bolts that are inside of the bushings on the subframe? I tried unscrewing them but it's impossible, looks like its too tight or rusty.
Do they have inverted thread by any chance?
Thanks for your help!
As far as I'm aware these are RH thread into the body so they should screw out in an anti-clockwise direction, Try to "tighten" them slightly before "undoing" them.
Althulas
Banburyshire
M Roadster
I used two Spanners interlocking for more leverage and had to put my weight behind it as Lee said to me it will make you want to fart=)) just don’t have a dodgy curry the night before unless your wearing safety under pants. My plan B wa to angle grinder off and use the impact gun but plan A worked. As Tony said they are normal thread righty tighty. Good luck .
As said above. 27mm spanner, feet against the wall and a change of underwear. They are locktited in from factory, once they crack they come out easy.
..................... Lefty Loosey. ........... @Nodzed ;)
If you have a big enough knuckle bar you can get them off either way ............apparently...........:thumbsup:
