Rear speakers..
Discussion in 'GadgetZ, GismoZ and Bling' started by z3cade, Mar 7, 2012.
  1. z3cade
    z3cade Zorg Guru (III)
    Dec 4, 2011
    1,980
    315
    137
    Peterborough
    I know this is been asked so many times but what have people upgraded there rear speakers with?
    Has anyone managed to get bigger speakers in there to improve bass tone ?
    I did have a sub in the 2.8 but dont want it in the M and would rather get a decent speaker set up...
    Im currently running an Alpine head unit with standard speakers
    Thanks
  2. badman gee
    badman gee Guest
    the speakers you have are good enough.
    especially for that rubbish you play :)) :)) :))
  3. Daz3
    Daz3 Zorg Legend
    Dec 8, 2011
    618
    167
    75
    Spilsby, Lincolnshire
    Model of Z:
    I think the main issue is the mounting depth so if you wanted to go for a bigger speaker you'll end up having to cut the plastic behind the seat and mount the speakers on a spacer ring otherwise I think your limited to speakers roughly the same size as O.E, however just replacing these should see a difference in sound quality. On my system I'm running an alpine headunit followed by a vibe amp which is coupled upto two sets of vibe 5.25 components, in the footwell and behind the seats with tweeters in the door cards.
    Running the speakers from an amp makes a huge difference in loudness and quality well worth it imho.
    Once installed I find this song best to set up the bass lol :-bd :D
  4. z3cade
    Dec 4, 2011
    1,980
    315
    137
    Peterborough
    Thanks Daz but i listen to more along the lines of this music so i`ll use this to set up my bass :-bd
  5. badman gee
    badman gee Guest
    i like it :D :ymapplause:
  6. board
    board Administrator
    Staff Member Administrator Global Moderator British Zeds M Power
    Dec 2, 2011
    1,379
    68
    88
    Cuiaba
    Model of Z:
    M Roadster
    this one will do it :D
  7. z3cade
    Dec 4, 2011
    1,980
    315
    137
    Peterborough
    So 5.25 13cm speakers will fit with abit of modding?
    Do they have to be shallow fit? Or do I need spacers
    Have you got a pic of yours Daz? :D
  8. Boysie
    Boysie Zorg Guru (I)
    Supporter British Zeds M Power
    Dec 6, 2011
    1,294
    190
    94
    West Chiltington, West Sussex
    Model of Z:
    M Roadster S50
    Thats what i enjoy about this site a sensible question
    Total mayhem =))
    Then back to the question in hand
    luv it
  9. z3cade
    Dec 4, 2011
    1,980
    315
    137
    Peterborough
    You've got to have abit of fun hey Boysie ;)
    There's agood thread on .net if you haven't seen it already.. 'M Power Badge'
  10. Snoops
    Snoops Zorg Addict
    Dec 10, 2011
    338
    4
    51
    Red Rose Country
    Model of Z:
    2.8
    Is that thread still going..... it's a lot of fuss over a badge don't you think (-|
  11. Daz3
    Daz3 Zorg Legend
    Dec 8, 2011
    618
    167
    75
    Model of Z:
    Lol I like that one Liam! I did half answer the question before I made a not so sensible conclusion :D
    I don't have a pic Liam and my cars all stripped out at the minute I'm sure someone else has done this?
  12. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,111
    9,174
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    There are long threads on M badges on most BMW Forums, I guess our own one will probably start at some stage!
    There is one on Pistonheads which is 31 pages long now, and it's hilarious!
  13. z3cade
    Dec 4, 2011
    1,980
    315
    137
    Peterborough
    Thanks Daz, I'm looking at ordering a set of speakers from eBay and didn't want to get a set if there to deep.. Shall have to see what's behind there..
    Regards the badge thread I agree it is a little OTT but just trying to say its good to add a bit of fun a laughter to these sites as sometimes they can get a little to serious and mundane..
    As long as your not offending anyone I think it's ok ;)
  14. zedonist
    zedonist Guest
    Hi Liam,
    See my post below on what fits:
    viewtopic.php?f=14&t=766
    5.25" will fit, you will need to cut the plastic and you will need spacer rings, if you can buy shallow basket speakers, but i do recommend that you get some around 75 - 100 RMS to make a difference, you will need an amp, but with the Alpine uit you can buy an inline amp that requires no extra wiring as it plugs into your loom (KPT-445 - amp) I have this fitted and it is good.
    I am currently drawing up some custome spacers so that i can minimise the space used, as currently to get a fit i have used to 10mm thick spacers. I think it should be about 12 - 15 mm, I will have these machined out of aluminium and polished, let me know if interested might be cheaper to buy more than two.
    Rich
  15. g8jka
    g8jka Zorg Guru (III)
    1,879
    1,167
    148
    Telford, Shropshire
    Model of Z:
    Z3 - 2000 2.8 Roadster
    I have 4" Vibe Slick speaker behind the seats, pretty good sound for the price. This is off my journal:
    Up next were the rear speakers, which were a little harder to fit. As there is no room behind the original speakers it is impossible to get a decent set of 4" speakers in. Because the mounting depth needed to be larger with my new speakers I had to mount them on the outside of the trim. I used a dremel to cut away at the original trim so the speakers would fit flush and screwed them straight through this into the screw holders already in place.
    [​IMG]
    Too get speakers with more depth in you can mount them on top off the trim giving you a little extra room without the use of a spacer. You may need to cut away the trim but then the speaker can be mounted on top and screwed through the trim plus you can use the original wiring.
  16. z3cade
    Dec 4, 2011
    1,980
    315
    137
    Peterborough
    g8jka many thanks for that :ymhug:
  17. heath
    heath Regular Member
    Dec 22, 2011
    88
    19
    Burton on Trent
    Model of Z:
    Z3 2.0 individual
    I fitted 5.25s in mine & made some spacers out of old speaker grills to get them to fit but they taper in where they fit to the trim so it makes them look a bit "stuck on" so I might buy some proper spacers in the future but for now I think they look ok :)
    Heath on Tapatalk
  18. z3cade
    Dec 4, 2011
    1,980
    315
    137
    Peterborough
    Thanks guys, I've just had a quick look behind my seat and the rear speakers are different in the M :(
    There about 2.1/2 inches wide and the panel doesn't come off.. How the hell do these come out?? :-?
  19. Daz3
    Daz3 Zorg Legend
    Dec 8, 2011
    618
    167
    75
    Model of Z:
    You'll need to remove the roll hoops and the surrounding trim to gain access through the top.
  20. z3cade
    Dec 4, 2011
    1,980
    315
    137
    Peterborough
    Hang on..... Is anyone thinking what im thinking??...
    Gary the Fish???? :-ss x_x
Share This Page
