A sign of the sad times we live in.I can see where the fitter is coming from - working outside of OEM standards; in his mind, may leave him liable if something untoward happened .
Isn't the rear beam different also on a narrow prefacelift ?N4LLY's car is a facelift so wider body than the MK1 4pot (and different rim) so not a good comparison really, best go with your measurements on your car (suspension height affects things too).
No problem, will do. Car's April 1997 but likely the same.be interested to see pics before and after of a narrow body 4 pot 1998 model...
No, they would protrude by at least 5mm.You've got loads of room left.
Whack some 20s on
