rear shocks
Discussion in 'Z3 Roadster & Coupé' started by phil.a, Nov 15, 2014.
  1. phil.a
    phil.a Zorg Legend
    Jul 18, 2014
    336
    334
    77
    redditch
    Model of Z:
    z4
    one more job done, replaced the rear shocks, what a easy job, first one i took the wheel of and thought you can do this with the wheel on it took just as long to put axle stand under, know wait for the new springs and all good to go
    • Like Like x 1
  2. David Cullen
    David Cullen Zorg Legend
    Supporter The M44 Massive
    Jul 8, 2014
    760
    366
    76
    Prosperous, County Kildare
    shocks were bad Phill? leaking? what springs you doing? standard or dropping?
    • Agree Agree x 1
  3. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,210
    9,349
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    Yes, more info on what you have changed to as I'm doing mine soon :)
    • Agree Agree x 1
  4. phil.a
    phil.a Zorg Legend
    Jul 18, 2014
    336
    334
    77
    redditch
    Model of Z:
    z4
    put sachs shocks meyle hd bearing and will be putting kyb standard springs, it looks like the shocks were on car from new, was not happy with the handling so thought they might be past there best off side spring broke at the bottom, i recon we heard the spring go last sunday, as we pulled up at the lights we heard some think fall of the car but could not find anythink, but mot man found it, once got them sorted and mot on will have a go at the anti roll bar bushes and drop links
    • Like Like x 3
  5. David Cullen
    Jul 8, 2014
    760
    366
    76
    ARB and bushes are another handy one Phill, you uprating or just replacing the drop links and bushes?
    how is the drive now with the new shocks?
  6. GazHyde
    Dec 2, 2011
    15,210
    9,349
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    I shall probably be fitting Sachs shocks again, would love to be able to afford Bilsteins but a luxury too far at the moment!
    • Like Like x 1
  7. phil.a
    phil.a Zorg Legend
    Jul 18, 2014
    336
    334
    77
    redditch
    Model of Z:
    z4
    replacing drop links with meyle arb bushes poss stay as standard last ones have lasted 14 years and still pass the mot, not done a test drive yet will wait till i fit the springs next week,
    • Agree Agree x 1
  8. zedonist
    zedonist Guest
    Try Bilstein B4's, these are the same price as Sachs, or for a few quid more are the B6's, but these may be too sorry for you, I have the B8's fitted which are shorter versions of the B6 to be used on lowered suspension, i think the ride comfort is sublime with them.
    • Like Like x 1
  9. zedonist
    zedonist Guest
    Just a reminder, shocks and springs are there too keep the road wheels in contact with the road, harder springs and uprated dampers do the job more quickly, so can seem harsh, so this is ride comfort, not much handling performance gained from this.
    Ride handling is determined by the amount of body roll and pitch, harder springs will lessen the amount of pitch (bobbing like a boat), but the real transformation comes from stiffening the ARB's, as this lessens the amount of body roll and corner pitch, therefore if you want handling performance but don't want to lower your car, change the ARB's first, you could also fit gas filled dampers, but you will find it hard to find standard height stiffer springs, but IMHO you won't need them.
    • Like Like x 2
  10. oldcarman
    oldcarman Zorg Guru (V)
    Supporter Canadian Zeds The M44 Massive
    Feb 11, 2014
    9,986
    3,617
    177
    Pine Falls Manitoba can.
    Model of Z:
    Gary, maybe if you weren't so generous buying breakie for blondes you could get the Bilsteins sooner. lol JIM
    • Agree Agree x 2
    • Funny Funny x 2
    • Like Like x 1
  11. phil.a
    phil.a Zorg Legend
    Jul 18, 2014
    336
    334
    77
    redditch
    Model of Z:
    z4
    update fitted shocks and bearing replaced both springs took for test drive and now i have a warning light on it looks like the ASC LIGHT orange triangle with ! on it i guess i have disturbed something but cant see anything wrong cleaned the sensor it seems ok,:( will i ever get it through the mot:eek:
