- Joined
- Nov 20, 2013
- Points
- 89
Following the success of my front and rear upper strut braces I have developed a rear lower brace.
This is a low profile steel brace that connects at the rear lower subframe mounts utilising the existing bolts.
The aim is to reduce the Z3's characteristic loose rear end feeling in mid to late cornering. I have tested them and also had the benefit of @Brian H and @Rha testing the brace fit and performance.
I found significant improvements and minimal loss of ground clearance.
The braces will be provided with 4 x 3mm spacers that you can use if needed to lower the brace if you have a clearance issue with your exhaust. (I have fitted it to several cars with standard and replacement exhaust without issue.)
They are provided in black powder coat (but don't expect it to last forever as its under the car)
i also do a deal with the front and rear strut braces. (all three braces for: £299 + £20 shipping or both rear braces for: £199 + £10 shipping in the UK) (worldwide delivery is an addition £20 per brace - so an additional £40 for two and £60 for three braces)
you can order them on my website:
http://www.bertinigt25.com/z3-braces.html
What a team these two braces would make
fitted to @Brian H's car
another fitted picture with standard exhaust
