Jams
Hi all,
First post here and and I can’t seem to find this bedded in a post so far...
I’m replacing my rear wheel bearings which involves removing the rear half shafts/axles. I’ve managed to remove the 6x E12 torx nuts on each side of where the shafts meet the differential flange, however NO movement at all in removing the shafts from the diff. Tried loads of prying and WD40 to no avail!
I can’t quite seem to figure out at which point in the rear shaft does it separate from the diff flange (photo attached).
Any advice would be appreciated - cheers.
Jams
Jams
