Rear fog light
Discussion in 'Z3 Roadster & Coupé' started by Barry Gadd, Nov 3, 2014.
  1. Barry Gadd
    Barry Gadd Zorg Addict
    British Zeds The M44 Massive
    Mar 29, 2014
    118
    64
    46
    Woking Surrey
    Model of Z:
    Z3 1.9L
    My Z3 failed it's MOT today.......... BUT for 2 relatively simple problems.
    1) The rear fog lamp won't switch off.
    If I switch the rear fog on it won't switch off using the same switch.
    If I switch the front and then the rear fogs on I can switch off both using the front fog switch.
    I don't have the UK owners manual and the USA version (which a ZRoadster member kindly put on the forum) doesn't have rear fog lights.
    Can anybody advise what is happening here?
    2) Front O/S caliper sticking. I did free this some time ago but it must have got stuck again.I'll set about freeing it tomorrow.
    Thanks guys.....nearly there.....
    • Like Like x 1
  2. oldcarman
    oldcarman Zorg Guru (V)
    Supporter Canadian Zeds The M44 Massive
    Feb 11, 2014
    9,991
    3,617
    177
    Pine Falls Manitoba can.
    Model of Z:
    @Barry Gadd, and I thought my ordeal waiting for my car to arrive dragged on and on!! You are almost there, at long last. JIM
  3. t-tony
    t-tony Zorg Expert (II)
    35,274
    16,347
    Model of Z:
    Z4 3.0 Auto
    Barry, when you take your brakes apart pay particular attention to the slide pins. Where these pass through the calliper body there is a rubber "sleeve" . IF you haven't done so already remove these sleeves and clean the holes they fit in, also scrape any crap off the rubbers before refitting them into lubricated holes. Clean and grease the pins with a light spray grease only, NOT copper grease. This is often over looked but is also often the root cause of brakes sticking, assuming the calliper Pistons and dust seals are in good order too. HTH.
    • Like Like x 1
  4. t-tony
    35,274
    16,347
    Model of Z:
    Z4 3.0 Auto
    What year is your car please Barry?
  5. Barry Gadd
    Mar 29, 2014
    118
    64
    46
    Woking Surrey
    Model of Z:
    Z3 1.9L
    My Z3 is 1997
    I did as you advise Tony but a few months ago, and the car has been standing since then.
    I will clean the caliper sliders etc again and make sure the pads can slide easily. I think I used Copper grease last time so I'll use a high temp grease this time. I also used a G clamp to gently squeeze the piston back into the cylinder,carefully lifted the edge of the rubber dust seal and dribbled a couple of drips of brake fluid to help avoid the piston sticking. I think this can help. Any other ideas?
    Thanks for your help.
  6. Brian H
    Brian H Zorg Guru (V)
    British Zeds Scottish Zeds
    3,611
    2,599
    195
    Killin
    Model of Z:
    E36/7 3.0i - E85 Z4///M
    Interesting you should say this Tony, I previously did just this but found the rubber sliders turned to jelly, For the past few years (on the advise of forum members) I have not used any lubricant at all on the caliper pins and rubber boots and they have been just fine.
    Hi Barry,
    Sounds like a broken switch to me, the mechanical latch inside the switch seems to be sticking, you could maybe try a specialist switch lubricant, failing that see if you can get a replacement either secondhand (@spurs fan in a coupe) or a new one.
    Brian
  7. t-tony
    35,274
    16,347
    Model of Z:
    Z4 3.0 Auto
    Most new or reconditioned callipers we use at work come with a silicon grease in a small sachet to grease the slider pins, also the spray greases we use contain silicones and don't destroy the rubbers. I think that was what ruined the rubbers on your car Brian. My comment re copper grease is that it conceals and turns to a solid restricting movement. In the right applications it's great stuff.
    • Agree Agree x 1
  8. hard top
    hard top Zorg Expert (I)
    Dutch Zeds The M44 Massive
    20,950
    6,112
    213
    Netherlands
    We use buckets off the stuff on Carbon Drill Pipe, Casing & Tubing etc, as the copper particles are the lubricant for make up and we don't care about breaking out again as huge power tongs do that job.
    I have seen stored pipe connections not properly protected and the stuff does harden up and you need a steam cleaner to get it off.
    #8 hard top, Nov 4, 2014
  9. t-tony
    35,274
    16,347
    Model of Z:
    Z4 3.0 Auto
    Like I said Mike it has its uses, I use lots but only in the right places.:)
  10. hard top
    20,950
    6,112
    213
    Netherlands
    Bad Boy will love you then.......;)
  11. oldcarman
    Feb 11, 2014
    9,991
    3,617
    177
    Model of Z:
    Could this replace soap on a rope?? JIM
    • Agree Agree x 1
  12. t-tony
    35,274
    16,347
    Model of Z:
    Z4 3.0 Auto
    I think you're confusing this with Molyslip Mike !!=))
    • Like Like x 1
    • Funny Funny x 1
  13. Nifty Fifty
    Nifty Fifty Zorg Legend
    Jun 26, 2014
    257
    245
    68
    Wylye
    Model of Z:
    2.0
    you lot are NUTS:bashhead: It took only 6 x serious reply's before it all turned to smut!! and soap on ropes:joyful:
    • Agree Agree x 2
  14. Brian4
    Brian4 Zorg Guru (IV)
    British Zeds East Anglian Crew
    Dec 23, 2011
    2,591
    2,077
    173
    Hinckley/Burbage
    Model of Z:
    Z3 3.0i Auto
    Hi Barry I was thinking it is either a sticking switch or the relay which is under the dashboard. The wiring diagram says it is left hand side but it is american and the switch is on the left there obviously so the UK relay may be on the right. I'm rambling now.
  15. zedonist
    zedonist Guest
    When I did my front calipers I started to grease them, but on reading the TIS it said not too, the reason is the grease traps dirt and crap and causes the pins to stick and not slide, so I left them dry, and they are perfect.
    • Agree Agree x 1
  16. zedonist
    zedonist Guest
    Is Molyslip HT's Girlfriend?
    • Funny Funny x 1
  17. hard top
    20,950
    6,112
    213
    Netherlands
    That's what they are all called in Amsterdam
    • Like Like x 1
  18. Brian H
    3,611
    2,599
    195
    Killin
    Model of Z:
    I knew I had read it somewhere, several sets of pads later and no ill effects from having no grease.
  19. t-tony
    35,274
    16,347
    Model of Z:
    Z4 3.0 Auto
    What is TIS Brian/Rich please? I can appreciate excessive grease would attract dust etc which is why I use silicone grease ..... it doesn't
    Why would you think calliper suppliers give you a sachet of grease to use if it was a bad idea?
  20. hard top
    20,950
    6,112
    213
    Netherlands
    Christ Tony, and you are doing MOT's.
    Technical Information System (TIS) includes workshop manuals, wiring diagrams, vehicle testing manuals and technical service bulletins.
    • Funny Funny x 1
