Rear drop links
Peter1450
Bristol
Z3 3.0
As above , wife’s 3.0 Z3 new rear drop links keep sliding off anti roll bar , all new parts including the brackets onto the rear arms ,any suggestions as to why? TIA
Ade33
Stratford upon Avon
3.0 Sports Edition
Not sure if this will help but worth a read
Peter1450
Bristol
Z3 3.0
Cheers Ade, thanks for the link, will have a play with the angle of the bracket’s, I thought they could only locate in the one position.
Steve Medlock
Tenterden, Kent
You do need the droplink bush to grip the roll bar which is easy if its nice and rusty but harder if you've nicely painted it, so if you use a lubricant to slip bush onto the bar, use diluted washing up liquid or something that will disperse. Don't use a rubber lubricant as this will allow the bush to rotate and slip rather than gripping the bar and staying put.
Peter1450
Bristol
Z3 3.0
Exactly Steve , had that very senior moment adding nice red rubber grease to get them on obviously makes them slide straight back off😂 Lesson learned, the clips seem a very good idea ,thought I had some in the garages but no , so will get some just for peace of mind , still think it’s a crap design! Didn’t someone here say BMW they changed it sometime after?
Drill a hole near the end and put a large washer on the bar and an "R" clip through the hole?
Not sure if its been mentioned but the bracket that holds the droplink at the bottom is sided. If its the wrong way round it try's to tilt the drop link when the car is cornering.
AntStark
Hampshire
2002 3.0 Sport
Hairspray.. use it all the time for securing rubber mountain bike handlebar grips to bars. Slips on, dries like glue
I knew I recognised that smell when you was walking around in the shed =))
Peter1450
Bristol
Z3 3.0
How do you know the brackets the correct way round Lee?
