Okay here is the update now that I have picked up the car and driven it home. I'll try and explain it as best as I can. It may end up being edited in the event I get something wrong.
Firstly, further example that I know nothing about cars: The car wasn't even lowered. My father had questioned this a couple times in the past. Seeing it hoisted up proved him correct. The camber on the tyres is stock standard. The wheels are 18 inch btw. The suspension specialist said he had worked on this kind of incident multiple times before, though admittedly hadn't worked on BMW sub frame in a long while.
The problem is that the rear sub frame area is all very exposed to hitting objects sticking out of the road (large rocks embedded in dirt roads, etc) and if the front of the cross member takes a hard hit to its forward side under there, then with the force of the moving car, it is possible to bend the cross member forward - pushing the trailing arms and gearbox fractionally and redirecting the tow of each tyre inwards.
This causes the tyres to compete with each other which wears the tyres excessively and causes the car to move around on the road a LOT with new tyres (which mine does). This appears to be what has occurred in my case. The damage is not visible on the cross member itself (it is bent so the angle is slightly deviated), and there is no visible damage (that we noted) to the rest of the sub frame. What makes the damage clearer is the toe of the tyres.
I edited the above oem graphic to hopefully explain what I mean a little more. I hope it helps.
