Wanted Rear calipers
Sean d
Lincolnshire
Just testing the water guys as I did my fronts yesterday and it was a nightmare trying to get them off painted and fitted so I could drive the car home, so I am thinking of getting a set and doing them at my leisure so it would be just a case of swapping them over, is the 2.0l the same as the 1.9 on the rear
@spurs fan in a coupe
@Synclare
What sort of money are they
thanks
I seem to remember rear callipers are the same across the range excepting M models Sean.
Run the last 7 digits of your vin number through realoem.com, find the part you need and then click on the part number. You can then see which other BMW models used the same calipers. I ran through the details on my old 2.0, and came up with this list of compatible models.
Part one on the diagram
Is also fitted to the following models.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
