I finally got around to replacing my rusty horrible back plates. Over several months (!) I collected parts, back plates, FAG bearings etc. and tools, slide hammer, bearing pullers, shaft puller etc etc and then waited for some decent weather.
The drive shaft was disconnected from the diff, hub nut removed and driven back out of the hub. With ARB and shock disconnected it was still a fiddle to get it clear.
The slide hammer pulls the hub from the bearing.....(eventually after it seems like its never going to move)
The remains of the bearing can then be removed from the hub. Laser tool not great but did the job.
The main part of the bearing can then be pulled. (accompanied by a high degree of grunting and groaning)
At last the horrible back plate can be removed!
New back plate is fitted and new FAG bearing pressed in place and big circlip fitted.
Now is the easiest time to re-install the handbrake.
The hub is pressed back into the bearing.
The drive shaft can then be replaced. One went in quite easily but the other one, I couldn't have done without the shaft puller kit which makes it a straight forward job.
Looks easy doesn't it. Maybe but it took me the best part of two days each side!
