The rubber seal that drivers door shuts on to has two holes where someone in the past has caught it with ?, how easy is it ti fir a replacement and does anyone know the part number or maybe Sopers would know
Geoff
Geoff
That could cause water to leak in. That happened on my car. I taped it with gaffer tape as a temporary measure.The rubber seal that drivers door shuts on to has two holes where someone in the past has caught it with ?, how easy is it ti fir a replacement and does anyone know the part number or maybe Sopers would know
Geoff
Thanks for that I will keep you posted GeoffThat could cause water to leak in. That happened on my car. I taped it with gaffer tape as a temporary measure.
It's easy to replace as long as you are happy to remove the inner trim plastic. It just needs a sharp tug at either end as it's held on with some hefty clips. The trim is very rigid. Risk of damage low. The part number for all models is
51718397376
If the price is prohibitive at about £50 I should have a decent secondhand one if you PM me.
