Sometimes it is good to know how challenging a repair is going to be before you attempt it yourself, especially if you are a noob like me. So, I was wondering if we could rate some DIY repairs.
Base the difficulty from 1-10 [one being easy to ten being almost professional/ experience required]. Take into consideration time, special tools needed, access to the parts etc. I will start. Disagree if you want!
Level 4. Pull the dash out. this involved centre console removal, do research first, lots of work but not hard.
Level 4. Replace the oil filter housing gasket. Fan removal can be challenging and needs special tools, hard on the back and shoulders, easy to put back together once you have taken it apart. Many parts to be removed.
Level 1. Replace grommet for the radio whip antennae.
Level 2. Replace fan belt. Have to remove fan and shroud first.
Level 2. Install under footwell lighting. Tracking wires to centre light near mirror and soldering in is fiddly.
So, what about front shocks, rear shocks, Vanos repairs, engine rebuild, rocker cover gasket replacement, etc, this is just to get some opinions!
Cheers, Cooper
Cheers, Cooper
