radio aerial linked to alarm ?
joepig
preston
Hi.some b******* snapped of my radio aerial but snapped it off at the base unit,now the remote central locking still worked,but you can't live without the radio,so I took the aerial base unit out without disconnecting the battery(frightened of losing the radio code)there are a couple of connections to the securing bolt and I think there could have been a small short circuit flash as I disconnected them , anyway I repaired the unit,re-soldered the wire inside that makes contact with the aerial and put it all back together,good job I thought, but now the central locking does not work on the remote but still works ok on the key.I've checked every fuse and they are all good , so my question is was there a short and I've caused some damage or have I botched up the repair to the aerial and is the aerial connected to the remote alarm/central locking system,thanks for showing an interest any help please.
hard top
Dutch Zeds
Netherlands
That will probably have something to do with not disconnecting the battery but having said that, I had the same problem when my battery went flat....:confused:
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
I had the same problem with my aerial and had to remove the base unit. If I remember correctly the larger of the wires is the earth for the head unit / CD changer (if fitted), the two smaller ones being power and earth for the aerial. I also had sparks when disconnecting, but all was OK after refitting. It could just be a coincidence and your remote battery has died at the same time.
Eddie Zedder
Z3 2.0
hi,thank you for the encouraging reply , it gives me hope,will fit new remote battery though the little red light still shows on the "brick" , thank you
Worth a try. Not sure if you have to reprogramme the remote when changing the battery. I know when I have changed my Freelander one you have to press one of the buttons 6 times in succession for it to align itself with the car. I should think there is a section in the owners handbook about this.
Put a new battery in my "brick" some months ago and worked fine first time. The alarm did throw a track when the car battery went flat though. After a few minutes of opening and closing on the fob it sorted itself.
