Quick Question
stevie_a
Glasgow'ish
I now have my powerflex diff bush and with a bit of luck some time to schedule in to fit it
Can this be changed when the car is on the ground?
do you have remove the diff?
Can it be done by just removing the diff bolt at the bush ?
Ok ok three Questions.. :whistle:
stevie_a
Glasgow'ish
@Lee As said on the post Gaz has shown, have you actually changed the diff mount this way?
Is it just a case of jack up car, put on stands and undo diff mount bolt and let diff down on the jack and change bush?
From what I understand and from experience Stevie, the toughest bit is getting the outer "shell" of the old bush out. After a clean in the housing the new one pushes in by hand.
