Hey All,
Thought I would create a thread to document my progress on my new project for the Summer and beyond!
I'm slightly lame and name all my cars, and my Z will be called Desmond because its a 2.2 and as my gf is a Saffa ( as is Desmond Tutu ) so she has a connection too and isn't left out.
Desmond has 69.5K on the clock, Manual transmission, 2.2L 'Sport' finished in Topaz Blue body / Black manual roof with type 78s.
I've got a long list of stuff, many of which I will attempt to do my self so will be a great learning experience. I also live above a small car workshop in West London, so if I really screw things up there is a bit of a safety net, although they will be quite pricey so will be on the look out for a local-ish specialist if people have any recommendations. Generally trying to keep it as OE /OEM as I can, although may make some exceptions i.e. the stereo system.
I don't really have any car tools, so one of the first things I will need are a good set of tools (torque wrench? ) and a proper jack me thinks, along with a manual ( I hear Haynes manuals for 3 series 92-98 ) are a start. I do have a multi-meter and an OBD II diagnostic tool which I got from Euro car parts, but it doesn't seem to work on Desmond...It does work on my other Car, Alan ( a Golf Mk 7 ) - are there something particular about a Z which requires specific compatibility??
Otherwise would be good to hear of any must have tools or bits that will help me along my quest to restore Desmond to the glory he deserves.
Anyway, I've compiled a list of the bits and bobs I have found (so far) that will need work on below. If people know of any of the parts available or pointers that would be of much help!
Mechanical :
Exterior
Interior:
Any advice for a newbie would be much appreciated, I am very handy with DIY for a house incl. electrics and plumbing, but never have touched my cars so that needs to change! Otherwise, how would I go about finding the part number refs I see get quoted about??
Cheers,
Billy ( aka Nabs )
Mechanical :
- Oil warning lamp sometimes comes on when in neutral.....although turns back off when driving - Seller tells me she previously had an oil pressure issue which was resolved but her garage couldn't turn off the light. Probably the most major issue of the lot as I know this can be a whole host of costly things so am really hoping its just the sensor.....Any ideas what it could be? FIXED July
- Front Brake pads/Discs need changing - FIXED May
- Unknown if water pump has been changed...
- Vacuum Leak error - FIXED May
- Vanos Error - FIXED May
Exterior
- Small rust patch appearing on each front suspension strut inside the engine bay, almost as if it has been rubbing against the bonnet lid, looks cosmetic only - Is this a common thing?
- Clouded front lights - FIXED April
- Cracked rear left light needing replacement
- Front right Indicator lens needing replacement ( I have the part with the car ) FIXED May
- Engine bay insulation missing a couple of clips that attach to the bonnet underside. FIXED April
- Sills - Very early signs of rust appearing by the edge of front arches. Will look to nip it in the bud before it gets out of control. The seller tells me she had the car undersealed about 5 years ago, MOT history suggests no history of rusting problems underneath, but am yet to see on a ramp myself, although have used an inspection mirror.
- Alloy refurb - Will refurb at some point
- Front respray - Will look to get front half done at some point, a few chips and scuffs here and there, otherwise maybe a detail on the rest of the car.
- Exhaust tips - Might look to see if I can get something chrome over the current stock ones.
Interior:
- Blank buttons missing for rear section behind handbrake / Stow compartments
- Gear stick - really tired and doesn't light up so will replace. I am not 100% sure if my car would have come with a chrome one or a black one, but the current one is black with M logo, but the prior owner thought it was aftermarket. Given its such a used and tactile part, I may go brand new OEM or very mint 2nd hand. FIXED June
- Chrome Headlight switch - Think they seem to have come faulty as standard from factory!
- Car mats - Need a drivers side matt, maybe will get some OEM look ones with a Z3 or M logo or something...
- Seats - Driver bolster has a tear and will need attention. I am looking to get the seats tidied up otherwise, but expect one bolster panel will have to be replaced...Is it cheaper to by another set of Sport seats? FIXED June
- Upgrade interior lights - FIXED April
- Head Unit - Thinking I may replace this as no bluetooth is really annoying. If I can keep it OEM look as much as possible that would be preferred so maybe will try to find a newer BMW head unit to swap with - Any ideas? Otherwise, is there a way I can keep the original head unit and add an auxillary Bluetooth function? maybe replace the 6 CD changer option to be the bluetooth?
- 6 CD changer in the boot is stuck and reads error....I may look to fix this if easy ahead of finding a bluetooth solution FIXED April
- Cassette deck in the head unit is stuck and reads error.... I had tried one of those cassettes to 3mm Jack devices to plug in my phone but managed to jam it..
- Speaker - Front right footwell speaker blown and rattles FIXED April
Cheers,
Billy ( aka Nabs )
