I'm clutching at straws asking but I will anyway.
When I put the replacement front subframe back on last night 3 of the bolts went in no problem. The 4th was stiff after 3 or 4 turns and then got stuck well before being fully home.
Now I'm always real careful about not crossing threads. If I can't do at least 3 or 4 turns by hand I stop. This bolt felt like it had gone into the thread fine.
I tried one of the other bolts that had gone in successfully and same thing. So it must be the thread not the bolt.
Is there anything that would cause this other than a cross thread? If somehow it is a cross thread then I guess all I can do is put a shorter bolt in and get the head welded to the subframe? But let's hope it doesn't come to that.
