The pipe have crimped type clips holding them on the components. How do you get them off.....and would the be reusable or should I replace with jubilee clips ?
Would it be ok to run the engine to see if I can see the leak?
Have looked (albeit a bit limited) at the steering box, steering pump and cooling bar and can’t see any signs of leaks in those areas.
Would a leak from the reservoir or connecting pipes manage to cover the plastic underbelly covers in oil?
