Powerflex Bushes
Discussion in 'Z3 Roadster & Coupé' started by JWilliamsZ3, Aug 14, 2019.
  1. JWilliamsZ3
    JWilliamsZ3 Regular Member
    Nov 11, 2018
    27
    23
    18
    Loughborough
    Model of Z:
    Z3 2.2i Sport
    So my Z3 handling needs improving as the Front Lower Wishbone suspension bushes have worn ( the rear ones ) and are in need of replacement, I've seen that Powerflex bushes have been recommended everywhere to stiffen things up a little.
    Question is do I replace the anti roll bar link bushes at the same time, does anyone have experiences of using/driving with these in? Thanks in advance
    • Agree Agree x 1
  2. colb
    colb Zorg Guru (III)
    Nov 25, 2012
    832
    577
    138
    Model of Z:
    1.8
    Irrespective of whether you fit Powerflex or OEM rubber to the anti rollbar if your replacing the lowers it would be good practice to replace the anti roll bar bushes that way you will have a fully fresh setup. Can't comment on which to go for my car is bog standard.
  3. the Nefyn cat
    the Nefyn cat Zorg Guru (III)
    Oct 19, 2014
    2,218
    732
    138
    Model of Z:
    2.2i Sport
    • Agree Agree x 1
  4. Sean d
    Sean d Zorg Guru (V)
    Supporter British Zeds
    Sep 29, 2015
    8,388
    8,336
    190
    Lincolnshire
    Model of Z:
    IMO its well worth replacing all of the bushes, if you want the car to perform how it was meant to, get the rear sub frame out oand replace all bushes, also replace all shocks, I did all of the above and and added Eibach pro springs, the difference is night and day
  5. Nodzed
    Nodzed Zorg Guru (V)
    Supporter British Zeds #ZedShed M Power
    Feb 18, 2016
    6,183
    3,720
    196
    Forest of Dean
    Model of Z:
    Z3M Roadster & e89
    Mines fully powerflexed front and back. Improves the handling but be warned it will be a harsher ride.
    • Agree Agree x 1
  6. Lee
    Lee Zorg Guru (V)
    Mar 26, 2014
    3,322
    4,175
    187
    Model of Z:
    Z3 Roadie 3.0
    Just to echo what everyone's saying you will also notice a little more noise, transmission noise through the bushes.
    I personally don't mind it, some people don't notice it.
    • Agree Agree x 1
  7. Pingu
    Pingu Zorg Guru (I)
    Dec 8, 2011
    847
    447
    95
    I would replace bushes that absorb shock with rubber, and bushes that just hold things that rotate with polybushes.
    • Like Like x 1
