Two days from MOT my powerwash for the headlamps has decided to pack up on both sides, wipers themselves work fine. Last week it worked fine, but I did run out of water last week.
My immediate reaction was it was probably sludge build up in water reservoir has clogged the pump filters (had that problem last year). So cleaned out the res, cleaned both filters, re-assembled filled with fresh water and tried again, still not working. Checked fuse 40 (30A) which was fine too. It got to dark to continue so need to pick up tomorrow.
Any ideas where to go next?
My thoughts are disconnect the hose from the water pump and see if it squirts anything out, but i am not sure how much water will flood out! If nothing squirts out check voltage across two pins to see if it goes to 12V after operating the windscreen washers, if it does it points to pump. If it does squirt i'm figuring it is a blockage in the pipe?
