Silver Baz
I'd like to replace this as its leaking , a couple of videos I've watched they have just emptied the bowl and replaced with new bowl and fluid , is there any bleeding required ?
Method as @colb has said you will see bubbles rising and level will initially drop quickly- recommended fluid Castrol Dextron IIICan you not use MTF ?
One litre enough ?Castrol Dextron III
Was on mine - took 900ml on both occasions I have changed it - forgot to say earlier do not hold it on full lock - strains the system you will hear it groaning if you do.One litre enough ?
