Thanks for the reply. After both 8&9 parts.Which piping are you looking for exactly.
@ZEDonist UK does 2 of them he sells the power steering cooling loop and the rack return pipe ( rack to cooler loop)
Stephen .
Thanks Martin@Stevo7682 thanks for the recommendation.
@Tomk it’s often the pipe from steering rack feeding the cooling the loop which fails as it corrodes quite badly. It’s site along the front of the steering rack so gets a bit of a blasting when we’re driving our cars.
I make the kit I supply. I’ve sold quite a few of them now and had good feedback so far.
The kit has everything you need as a straight swap and should last another 20 years
The high pressure line runs from the pump to the steering rack. The most common issue is leaking from the pump and/or corrosion.
In my opinion it’s always worth changing the flexible hoses to / from the power steering reservoir and the reservoir itself, whilst you’re at it.
I didn’t bother and ended up with leaking flexible pipes.
The reservoir also contains a non-serviceable filter.
The reservoir and flexible pipes are obtained fairly cheaply online from brands like Meyle and Febi
all the best
Martin
all the best
Martin
