I got caught out with that on the 2.8Also check that the frame is not catching stopping the roof from lowering. I assume you are pushing the roof part way up to make the system engage ? It will not work from a flat roof, when you just release the catches. Stupid to suggest but even dealers can get caught out with that one, like pushing the pedal down too.
Steve we had replaced the micro switch in the roof and thankfully replacing the console switch sorted it-thanks againWhich switch was it in the end JW ? Assuming not the microswitch but the one on the console.
Hi JohnSteve we had replaced the micro switch in the roof and thankfully replacing the console switch sorted it-thanks again
Great, Thanks for that,If you lift up your gear stick gator and lift up the foam you should have enough room to pop it up with your fingers.
