e36Ballen
- Joined
- Oct 10, 2019
- Points
- 18
Just want to confirm. I'm about to buy a lower mileage alternator because I suspect it's where this noise is coming from. Alternator pulley used to not spin straight (due to a loose belt the previous owner didn't replace) which makes it a suspect (bad bearings). But with the new belt, it's spinning straight now after putting in 500 miles (it got straigthened) but I still hear the noisy ringing on idle. I tested it before when replacing the belt but I'm still not sure if it's the alternator, it seemed kinda solid and spins after I spin. Alternator charges well.
Already did the screwdriver and funnel test. Couldn't confirm still.
EDIT: It's noisy on idle, warm or cold, but pressing the gas makes it pitch and go away.
I already replaced:
1.) Tensioner Pulley & Assembly
2.) Idler Tensioner Pulley (by the alternator)
3.) A/C pulley tensioner
4.) New Belts (Both A/C & drive belt)
Pending to be installed:
1.) New Water pump
I'm suspecting a vacuum as well but I have no CEL. Car is solid and runs well. M44 1.9 engine.
If someone has an experience with this, would appreciate any input. Thanks
