Just fitted a carbon fiber pipercross induction kit as i had it in garage from a previous vehicle.
It was anodised red so stripped it down and sprayed in the colour of the car (Black sapphire). Had to order a reduction (80mm to 70mm) 45degree bend black silicone hose from MAF to Filter and cut down to size. Then used an 80mm neoprene air duct to run the air flow to the existing headlight vent.
Think it looks good and gives a small increase in medium to high end growl and better throttle response across the rev range (absolutely not done for power...of which there shall be none extra anyway).
What do you think?
What do you think?
