Purchased from Andy but no longer needed as mine seems to have magically started to work again. Currently on eBay, but will let if go to a forum member for £30.
Hi
I am told that I need one of these but putting key in passenger door all locks work, but if I put it in either drivers door or boot only these two work.
Are you able to advise me ?
Mine was the same, only thing is I don't have a lock on my passenger door so can't try from that side but it makes sense if you can operate it from the passenger side manually. I can operate mine manually by pushing the pin down to lock and pulling the inside handle to unlock.
