Hi all.
I’m in need of help finding parts or part number for.
- ball pin / bolt
- Joining rod
I’ve attached two photos to help.
Take the clip off and the female section pulls off, you should then be able to get the remains of the rod out with a vise, or vise grips, maybe a bit of heat.
If needs be you can buy similar from here:
Get your Ball Joint- M8 Female - M8 Thread now. Shop for gas struts, gas springs, end fittings and more!
www.strutsdepot.com
Your problem is the rod is part of the ram, you either need a replacement ram from Andy, spurs fan in a coupe, or you weld a new threaded section . For that you’ll need Notherm, or similar heat dissipation compound, or you’ll likely kill the seals in the ram.
