Part number for a 2.8 1998 rear subframe
Mojojojo77
Hi I'm after a new rear subframe and was wondering if anyone knows the part number.. and if all subframes are the same for the 1.9 through to the 2.8 thanks ..
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
Hi Mojo
Welcome to the forum from New Zealand.
A couple of really useful links for you if you are new to the world of Z3 ownership:
- NewTIS is the BMW database of maintenance procedures and wiring diagrams etc https://www.newtis.info/tisv2/a/en/
- Z3 wiring diagrams can be found in this forums Resources section. Use your build date to select the correct set of diagrams https://zroadster.org/resources/
- RealOEM is the source for part numbers and exploded diagrams www.realoem.com
Now for your question on the sub-frame.
- Go to RealOEM and enter the last 7 digits of your VIN number and hit search.
- Bookmark the page for future use.
- Browse parts
- Rear axle
- Find the diagram with the sub-frame in it and click on it
- The sub-frame (rear axle carrier) is item 1, scroll down and click on the part number
- Click on "Z3 E36" and you will get a list of models that share the same sub-frame.
Althulas
North Oxfordshire
M Roadster
