It does latch bill and cleanly but if you don't slam it it won't latch. When we were messing with it we got it the best it had been since the body shop but like you say small adjustments must be able to improve it further. It was fine before the car was stripped.Dave if it is not shutting then you will need to work out if it is not shutting due to it being to far forward or to far back for it to latch, move it towards you and see if that improves if not then start adjusting it backwards, i am afraid it is trial and error untill you get it to latch.. But just do it a bit at a time.
