- Joined
- Dec 5, 2011
- Points
- 175
Been a while since I did one of these.
Problem = passenger door (RHD) wouldn’t open. Inner and outer handles would move, inner one would lift the locking door pin at the top of the door card, but it didn’t make the electronic/ sliding noise that it should.
This posed a problem as it was on my latest breaker and I’ve got a much loved member waiting for the wings - which you can’t get off without opening the door!
So I started by cutting a little window in the door below the handle. Suitable wing PPE applied.
This allowed me a subtle letter box to investigate.
Sadly all it proved was that the door handles were both correctly connected to the door latch / actuator. Doh - I thought I’d be able to pull one the arms and it would pop the door open. So I extended my ‘window’, now more of a bi-folding door.
This was entertaining, but still no luck working out what was wrong, so a bit of gentle persuasion to the actuator nearest the rear wing with a reciprocal saw and decent length lever….. first the saw pinged the latch enough to open the door to the safety latch…. Then an attack on the lower pivot point finally fully opened the door.
Happy days, now just to shut the door and no one would even know.
