Well today I started the following work:
Replace:
Thermostat & housing
Expansion Tank
Water Pump
Belts
Viscous fan coupling
It's been a bit of a pig so far. I'm in the process of removing all the old bits.
It started because one day I started the car, There was a loud shriek and whine, I then shut the car down, restarted and no noise. But since whenever I'm above 2.5k revs, there is a whistling/whining sound that sounds almost like a quiet supercharger? I thought it may be the belts so this is where it started. The car has got up to and maintained temperature fine.
Although I am beginning to think it may be a vacuum leak? I'm fitting M50 manifold next so depending on how this turns out if the noise is still there I can investigate further.
But I just removed the water pump:
I'm panicking a bit now, as I cant find the broken off bits, stuck my fingers in the opening but cant reach/ feel anything.
1. How bad is it that I cant find the bits and can I get to them anyhow?
2. Do you think this could be the noise culprit?
Feeling a bit disheartened, I have driven the car about 60 miles since the noise so if it was this then its not exploded anything......
Cheers.
Replace:
Expansion Tank
Water Pump
Belts
Cheers.
