Any ideas where it might be coming from by looking at the photos?
Pictures are taken from below, from the front of the car.
Thanks...
Thank you. Hopefully fairly easy to replace.Most likely place for this leak is the gasket on the oil filter housing block where it bolts to the engine block, item 6 in the oem parts diagram. https://www.realoem.com/bmw/enUS/showparts?id=CN12-EUR-04-2001-Z3-BMW-Z3_22i&diagId=11_6223
I checked that ad the cam cover was done recently. The top of the engine is all clean and dry.Or the cam cover
Thanks Colb, I replaced the gasket you suggested and now all fixed.Most likely place for this leak is the gasket on the oil filter housing block where it bolts to the engine block, item 6 in the oem parts diagram. https://www.realoem.com/bmw/enUS/showparts?id=CN12-EUR-04-2001-Z3-BMW-Z3_22i&diagId=11_6223
