Oil leak question.
cheeseandbeans
Oldham, Greater Manchester
Afternoon all.
So after my eventful weekend with the bottom ball joint snapping on my Z3 I've now had chance to put it on the ramp. Seems I have an oil leak coming from somewhere. It was all over the bottom of the sump and across the steering components. Question is are there any obvious places I should be looking before investigating this?
It's a 1998 1.9 if needed.
Cheers
Quite common for oil to leak from the oil filter housing/engine block joint gasket. Get a couple of aerosol cans of brake cleaner and thoroughly clean all the oil off. The run it and monitor where it appears from. A little oil goes a very long way and this has probably been going on for quite a while. Good luck in tracing and curing the leak!
just had the same problem fixed on mine today - oil all over sump and steering etc looked much worse than it actually was. Turned out to be a crank shaft gasket.
Got the zed back after a couple of weeks in the garage. All steering components have been replaced on both sides and a new exhaust back box fitted and it drives and sounds great. As for the oil leak, it appears to be coming from a gasket on the timing case, would that sound logical? It's number 4 and number 10 on these diagrams.
http://www.realoem.com/bmw/enUS/showparts?id=CH72-EUR-02-1997-Z3-BMW-Z3_19&diagId=11_0156
http://www.realoem.com/bmw/enUS/showparts?id=CH72-EUR-02-1997-Z3-BMW-Z3_19&diagId=11_2685
I've attached a couple of photos too. Best I could get at the moment but it looks like someone may have tried a quick repair with the amount of black gunk near the offending location.
Question now is, how big a job to change that out?
Thanks
