OEM Front Springs
Duncodin
Pontrhydyrun
Z3 M44
I was looking at RealOEM for part numbers of front springs. RealOEM doesn't show any for any of the z3 models I looked at? Am I looking in the wrong place? Anyone have a different page/site?
I've seen all the pages on thise site about recommended lowering kits But I don't want lower. I want Stock.
Matt Barnes
Portchester, Fareham
1998 BMW Z3 Individual 1.9 M44 B19
I have the shortcut for the 1.9... I found it under "Front Axle"... if this is what your after
interestingly when I select the Front springs section... it says no matching parts !
Duncodin
Pontrhydyrun
Z3 M44
Yes. I am. But, as you say, "No Parts found matching your car". Just found that strange.
Matt Barnes
it's the same for the rear's too !... just had a look....I'm sure they were there, as I remember cross checking the numbers in Ebay
DomiMik
German Zeds
🇭🇷 》Croatian living in Germany《 🇩🇪
As far as I know there are no springs listed because there are severel variations depending on the equipment of your car.
If you have air condition for example, your car is heavier on the front axle so you have different springs than a car without a/c.
If you contact your BMW dealer and give them your chassis number, they should be able to find the correct springs – won't be available as aftermarket though, I'm afraid.
Duncodin
Pontrhydyrun
Z3 M44
As far as I know there are no springs listed because there as severel variations depending on the equipment of your car.
Thanks. That makes sense. I thought the main difference was between 4cyl and 6cyl cars. I think I have the wrong springs in at the front because ride height is too high so wanted to put the correct stock ones in there.
Problem is that going to places like eucarparts or AutoDoc they list 3 or 4 OEM part numbers for the same Monroe spring (only using monroe as an example). What you're saying is that those 3 or 4 OEM numbers are the ones for different spec cars which suggests that the only way to really get the correct one is to buy OEM from dealer.
I Don't think its that mad on springs.
There's only a few variations, 6 cyl and 4cyl Sport and non sport. then M.
DomiMik
German Zeds
As written above, there are many more variations depending on the actual car configuration.
Sure there won't be any dramatic differences in real life but nonetheless BMW has a configurator solely for springs, it's only available through a dealer though. Here's what it looks like:
Show me the configurator for the Z3 platform.
So in this case then lets not confuse things and stick with what we know :D
Sorry if you have problems with accepting something that you didn't know before, that's not my problem though. I don't need to convince you of anything here 🤷‍♂️
You've not shown or proven anything other than generate confusion that's my point. The OP wants to know what spring to order not a list showing springs on an outdated database at a dealer. How does this help him...
Duncodin
Pontrhydyrun
Z3 M44
It could be worth trying to contact @spurs fan in a coupe , maybe he has some springs from a Z3 with similar spec like yours.
I thought of that but most z3's are well over 20 years old so would @spurs fan in a coupe know if a z3 he was breaking had the original/correct springs? I mean if he was breaking my z3 the springs look good so would he have any reason to assume they're correct for my car?
  • Agree
Reactions: Lee
Is your Z3 sport or non sport ?
In short could you climb on top of the tyre in the arch .
DomiMik
German Zeds
The OP couldn't find any part numbers and I explained why there aren't any listed on RealOEM.
Don't know what's so confusing about that.
It does look high, but a measurement (from the ground up to the wheel arch) might help and tyre/wheel size would also help compare with other owner‘s cars ? The thickness of the upper and lower spring rubber seat pads will also make a difference.
  • Agree
Reactions: Lee
