Odd Issue with the electric roof
lalinsorinoco
Hampshire
Z3 1.9 Orinoco
can someone help please, the electric hood comes up to the windscreen absolutely fine, but when putting it down, the section that connects to the wind screen (the top quarter of the hood) does not fully fold, but rest does. Now I've loosened the tap to operate manually. BUT, this is bugging me somewhat. Can someone shed some light please
Take some photos and add here so we can see the problem :thumbsup:
Mike Fishwick
French Zeds
Daglan, France
The switch is above the passenger window, on the hood frame - follow its woring to the connector
bertiejaffa
Manchester
Z3M
The microswitch is on the passenger side above the passenger window as mentioned. When you manually lift the front at the beginning of putting the hood down, the microswitch is on that "elbow" of the frame - its job is to check that you have pushed that back first before it powers the rest of the hood down process. The micro switch is "always on" meaning that when the roof is down, the switch is actually "off" and therefore there is no circuit. As you manually lift the front, the switch opens which actually closes the circuit.
On my old M I had an issue with the microswitch* which I replaced (easy search for a replacement on web but might need a little tinker to make fit.) I then had an issue with the wire** leading to the microswitch which I had to replace.
*Microswitch - if you have a test meter check the continuity when open/closed or cut the wires and twist them together to make a permanently closed circuit to check.
** for the wire I cut the wires at the back of the roof end and twisted them together - again this works but you have to remember to always push the front up first otherwise you will bend the frame
lalinsorinoco
Hampshire
Z3 1.9 Orinoco
Ah! I see, so unlock the latches, PUSH the front of the hood back to `switch off` the Micro switch, then press brake and engage the motor?
bertiejaffa
Manchester
Z3M
Pushing the roof up actually closes the circuit in the micro switch - its been a while since I looked at it but when you raise the front of the roof you will see the microswitch and the little arm that moves up and down against the front part of the roof and youll quickly realise what I mean.
Microswitch in the right place + Brake lights + Roof button = circuit
lalinsorinoco
Hampshire
Z3 1.9 Orinoco
Great! many thanks, I'll give it a shot when the weather has improved. Really appreciate your time with this issue.
Yes you have you push up the front of the roof hold it there then activate the roof
All you'd want to know about the microswitch ;)
lalinsorinoco
Hampshire
Z3 1.9 Orinoco
awesome!! Thanks
gookah
Shropshire
2.8 Z3
if you can move the roof without pushing the front up, the microswitch circuit is already shorted or bypassed,
That means if you haven't pushed the front part up, and then continue, it will not fold correctly and the frame can be damaged (if it not already is.)
It already looks like that has happened from the photo, as it should not look like that
comparison:
the roof should never go beyond the level of the bodywork:
something is bent on your frame,
Shorting microswitches should be for testing only, and then the issue fixed or this happens
AntStark
Hampshire
2002 3.0 Sport
@ZEDonist UK on here sells replacement microswitch kits if you find yours is duff
lalinsorinoco
Hampshire
Z3 1.9 Orinoco
comparison:
Oh dear! this mean a new hood then?
gookah
Shropshire
2.8 Z3
unless you can visibly see something bent, remove and straighten it, then it might be worth getting a second hand one from @spurs fan in a coupe
it looks like it maybe bent at each hinged joint, they seen to be pointing outwards.
does it move without having to lift the front flap first?
lalinsorinoco
Hampshire
Z3 1.9 Orinoco
So to update, located the Microswitch, followed the sequence that @bertiejaffa suggested and the hood went down with no complaints. That's one worry out of the way. It turned out there were no problems with the electric roof, just me not knowing how to operate it properly. Once again, my grateful thanks go to all who shared their knowledge.
