ODB reader recommendation
Timmo
Essex
2.8 wide body
Hi, can anyone recommend an OBD code reader that will work on a 1999 Z and a modern 1 series, only Im thinking of buying a 1 series as my every day car and it would be good if it could read both cars.
Timmo
Essex
2.8 wide body
Is that the Creator C310?
mwpe
Camberley
That is the one I have but I think there are newer one out there.
Newer Creator is the 410 available on ebay and amazon
Creator 310+ or 410+ both bmw specific and will work on most obd equipped bmw models.
For the z3 you will also need a 16 pin to 20 pin obd adapter to get full module access you need to use the 20 pin round obd port in the engine bay ( 16 pin under column only on later z3 and only limited access) your 1 series will work fine with the 16 pin under the dashboard.
Stephen.
