My 16 pin obd on the passenger side won’t connect to a scanner. The scanner powers on but it won’t connect to the car. I bought an adapter hoping the 20 pin would connect but that has the same response as the 16 pin. Turns on but has a connection error. I tried this scanner on another car and it works fine and I’ve used this scanner on my car before with no problems. I don’t see a fuse in the fuse box that has to do with the obd so I have no idea what to check. I’ve read online about fuse 26 and my fuse 26 keeps blowing but it says that is for reverse lights and automatic transmission. I’ve posted on several forums about my no start issue but have not gotten any real responses. I got an INPA cable and the program but obviously can’t connect it.
Everything happened after swapping the interior with the battery off for awhile.
