Not Z but speedo problem...
Discussion in 'General Banter' started by Warrior, Apr 16, 2012.
  1. Warrior
    Warrior Dedicated Member
    Dec 7, 2011
    151
    29
    Model of Z:
    3.0i sports automatic
    I have an ageing Citroen Berlingo van as my daily driver.
    Regularly serviced every 5 years :D the last time being 4 weeks ago.
    I had a smell of fumes in the cockpit which turned out to be some sort of breather that was choc a block with gunk and subsequently replaced.
    The suggestion was that the area the breather resided in could also have created dampness in the workings for the speedo hence it reading 10-20 miles below normal and that with a couple of decent runs it should re-calibrate itself. It hasn't......
    Any suggestions?
  2. Aceman
    Aceman Moderator
    British Zeds 3rd Party Trader
    2,221
    713
    156
    Wakefield
    Model of Z:
    ///M Roadster
    There is probably a sensor in the gearbox which if as suggested could have got gunked up connections and is causing it to misread, locate that and give it a clean.
    Other than that who knows.
  3. Warrior
    Dec 7, 2011
    151
    29
    Model of Z:
    Cheers Aceman, it seems to be a little closer to normal now, and i've not touched anything..... Need to get somebody to run alongside me to test....
  4. Aceman
    Aceman Moderator
    2,221
    713
    156
    Wakefield
    Model of Z:
    ///M Roadster
    .......or use a satnav, that will give you a true reading.
