Well, the project car is essentially back in one bit. The steering rack has been changed so we needed to bleed the system.
We filled the reservoir up (about 2/3rds and just touching the dipstick). Turned the steering wheel lock to lock 10 times with the engine off. Turned the engine on and then turned the steering wheel lock to lock counting to 10 seconds between locks and not resting at full lock.
We got a fairly unpleasant noise from the power steering pump, well I would imagine it was that. And the fluid was very churned up, quite milky looking.
Am I doing something wrong? Is it just air in the pump and I have to keep turning the steering wheel lock to lock until the noise goes away?
All orifices were covered during the work and kept clean so I don't think dirt got in. I used new crush washers on the 2 banjo bolts. There were no leaks on startup. The wheel turned smoothly.
