Noise - exhaust issues (Solved)
NeilH
I got my car back from the garage today.
Bmw z3 1.9
Its making a horrific noise coming from what sounds like near the steering wheel, steering column. Engine bay.
Its worse with the doors shut. Car only went in with a knocking noise at front drivers side which they think is engine mount as cant see anything else wishbones etc. It only does it from a full left turn on 1 corner to a full right turn on another (and not everytime) if anyone knows? Its one solid clunk when it does.
Also it had an exhaust bracket as was making a bit of a metal on metal noise at 3k rpm ish.
But now this. Its worse when the car is idling. It doesnt sound electrical but its like popcorn is popping in the microwave and it didnt have this issue before it went in the garage.nothing is physically shaking in the cabin that i can see.
Any help?? Ita going back the garage at 10am tomorrow so il keep you all posted.
Thanks
Neil.
NeilH
Couldnt get it too the garage as really bad snow. So going have take it in the week!
NeilH
Update
I think its exhaust related as it sounds more like under the footwell drivers side and when i try listen under the car it sounds like its coming from the exhaust. Maybe the sound is just travelling????
NeilH
Finally got car to the garage amongst the bad weather.
They adjusted all the exhaust supports and positioning and the noise has gone so must have been catching.
They did say my catalytic convertor could be on way out and rattling and making the raspy metal noise i hear when i accelerate... so that will be on the list to get at somepoint.
DrWong
3.0i
Thanks for updating on the outcome. Had similar on a previous car, garage fitted new back box but not tightened everything up, so was banging against the floor pan every time I put my foot down. They nipped everything up and all good.
Glad you got it sorted :thumbsup:
Glad Tey got to the bottom of it Neil, although the sad thing is they should never have turned it out in that condition.
NeilH
No problem and thats true Tony. Jury is still out on this garage but will give them another go when i get the cat con.
Would this one be fine. It says its a type approved 'none' but doesnt need be approved if before 2001? And mines a 98
Thanks
It does not need to be "type approved" for your car Neil. If you notice an issue when you collect it, if possible go straight back. That's the best way but I hope you don't need to.
NeilH
Excellent. Yea the only reason i didnt hear the noise last time was i had heaters on 4 and drove home whilst warming up. Then got to my drive and turned heaters off let it idle and i was like What the hell is that noise. I got a recording off it but dont know if can put on here. Cheers
Mark Parrish
Congleton Cheshire
Z3 1.9,3.0
I changed my cat for a type none approved also a 1.9 as it was starting to rattle 3 months later couldn’t get it through the emissions mot test the cat was useless I would definitely recommend a type approved cat as I have now done.
  • Like
Reactions: Lee
Ianmc
New Forest
Z3 (M44)
I found that only an OEM cat would work for the M44 engine. Tried two others which didn't work well enough to get within MOT levels.
Good luck!
  • Like
Reactions: Lee
RTV
Ireland
M44 Roadster
There's a reason why the scumbags steal cats, if you go with a cheap one there's also a reason for it.
Rest of the exhaust I'll be comfortable taking a risk, but the cat I wouldn't at all.
NeilH
Im happy to pay more for a good product.
Does anyone have any links to any for the 1.9 16v pre facelift 1998.
Nothing flagged on emissions on the mot last year so its probably fine just a horrible noise.
Thanks
NeilH
Just to report. New catalytic converter (type approved) fitted along with new middle piece between cat and backbox and all is fixed and sounding great.
Thanks.
Ianmc
New Forest
Z3 (M44)
Thanks.
Sounds good (no pun intended). Have you had the emissions tested?
NeilH
No i havn't sorry.
M.O.T due in June but emissions not flagged on last mot and that was a non approved cat on it 7 yrs before so fingers crossed it will be ok. 😬
