No window wash
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
Went to clean screen this morning but only wipers, when I returned home topped up water but not the problem. Cant hear the pump motor, fuse or pump motor failure ?
Any suggestions.
Thanks Geoff
spurs fan in a coupe
Any suggestions.
Thanks Geoff
If the wipers engaged then it suggests the switch is fine... So I'd say your fuse/motor diagnosis is spot on
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
Do I understand that there are 3 fuses controlling washer pump motor circuit
Usually a car will have fuses for the wash/wipe system as a whole. Not common for washers to be fused separately, but I'm not saying they aren't. My first port of call would be the pump itself Geoff, easy enough to test for power at the plug at the pump.
Antm72
South Yorkshire
The fuses are all related to the windscreen washer system so may do different jobs all part of the system one of which i presume is the pump.
As said a volt meter over the terminals pump end will prove the circuit if dead check fuses then test again if ok reconnect, if it blows theres a pump short, replace pump :thumbsup:
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
Checked fuses but number 3 missing ? others OK
Could see wet below bottle and the level had gone down since filling yesterday.
Went to see my mate the manager of the local garage, he rattled the bottle and it worked, so home now have taken the bottle out and the leak is from where the pump sits in. Will clean connections and see if can seal where the pump sits with a little grease or ?? and report back.
Antm72
South Yorkshire
Its a rubber grommit isn't it and i think the pump as it pushes through expands for the seal it may just be dirt as long as the bottle is all good :thumbsup:
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
Have cleaned it all up put a little grease on rubber seal, but it still leaks. Might try clear multi purpose silicone or
silicone lubricant or maybe it is not pushed right home. Will have another look after lunch
You could buy a new grommet from BMW Geoff.
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
Yes Tony if I have to, but I think that I have found the problem. With the grommet on the pump it will not go right home, hence the leak (I think) I have put the grommet in the bottle first with a bit of Silicone Lubricant then inserted the pump, put bottle back into position and locked up, filled, tested and so far no leaks.
If the pump not being pushed right into bottle was the problem that goes back to when I purchased the car and insisted on a new MOT. It failed and one of the things was wipers and washer so may be who ever did the job did not put it back right.
Fingers crossed.
Hope you've found the fault and have nailed it Geoff.:thumbsup:
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
Yes Tony, thanks. Back working on garden as out at the weekend with my TR4 on show for the West Somerset railway at Bishops Lydard.
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
Sopers dont have one, anything that I have asked them for they did not have, only a small leak when operated, so after MOT will buy a new pump.
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
Good news, passed its MOT this morning and pump still working with a small leak when operated. If there is no change I will replace the pump.
TR4 went well to and from show, great weather and crowds of people lots of interest in the car and on Sunday there were 14 Triumphs from the Somerset triumphs ie TR3, 3a, 4. 4a, 5s, 6s and Stags.
Sounds like it was a grand day out Geoff, hope the weather plays fair this weekend for ZEDfest too.
Geoff Crispin
Somerset
Z3 3.0 & 3.0 sport
Yes the forcaste down here in Somerset is good think that it is the same for you, where is the Zedfest being held ?
was at the fayre both Sat and Sunday, Sunday was heaving lots of great old cars & bikes etc.
It s at Shepshed near Leicester Geoff, according to the BBC weather forecast it should start to warm up on Friday !!
