Hoping for a little help or suggestions... 98 z3 2.8 manual, the speedometer doesn’t work, just sits on 0. I’ve done the “E36 cluster test” where you press the little button and turn the key to on, all of the dials spin like they’re supposed to. I replaced the speed sensor on the differential and cleaned up the connector. Haven’t pulled the cluster yet, not sure what I’d be looking for. Also, the fuel gauge is wonky, like it moves around a lot, but I thought that might be related to the fuel sender in the tank. I could live with that for now if my speedometer/tripmeter worked.
Is there any way to test the cluster or wiring? Is it a straight shot from the sensor to the speedometer? Lots of other things to do on this new buggy, but one thing at a time... Any help would be greatly appreciated!
