adrian_Z3
- Joined
- Feb 20, 2025
- Points
- 3
- Model of Z
- 1996 Bmw Z3 1.9l
Hello,
I purchased a 1996 BMW Z3 (1.9L, 120k miles) last December. Unfortunately, there is no heat coming from the AC system. However, the car does not overheat—the temperature gauge stays at the 12 o’clock position after warming up. The Hoses seem to be in good condition and are not kinked in a way that would prevent flow.
Steps Taken So Far:
1. Coolant Flush & Bleeding Air
2. Flushed the Heater Core
3. Replaced the Heater Control Valve
→ Shop suggested the URO heater control valve might be bad.
5. Replaced Heater Control Valve Again
6. Checked Blend Door & HVAC Controls
Adrian
Steps Taken So Far:
- Drained the old coolant
- Flushed the system with distilled water
- Refilled with new coolant and bled the system
- Had a shop flush the heater core
- Technician noted the core was really dirty—a lot of gunk and brown water came out
- Installed a cheap Amazon heater control valve → No heat
- Thought it might be defective, so I replaced it with a URO Parts valve from RockAuto → Still no heat
- Removed the aluminum thermostat housing, but one of the four bolts broke off in the cylinder head
- Took it to a shop—they removed the stuck bolt and reused the aluminum housing
- Shop installed a new thermostat and used a new paper gasket
- Ordered and installed a Four Seasons heater control valve from RockAuto
- Replaced Bowden cable behind the center console (black clip, center knob)
- I can hear the blend door thud when turning the center knob to Red
- Blower motor works properly at all speeds (1-4)
- Air redirection knob is functional
- Is the heater core still clogged? Should I replace it entirely?
- Could the water pump be bad? Seems unlikely since the engine isn’t overheating.
- Is air still trapped in the system?
- I’ve bled the air several times with the car on ramps—could air still be trapped?
Adrian
