No. 7 hex nut slipping!
Miffysmith
Hi all
(Z3 1.9 1997)
Couple of weeks ago, drivers side brake seized whilst on a short drive. Got The Lady home and with the help of an online video and my Bro-in-law, successfully removed the callipers, rubbed down and lubed the pistons, freeing the brake and providing trouble free motoring once again.
It was suggested I also do the passenger side brake.
This evening, having jacked the car up, taken the wheel off and the spring retainer clip, the VERY SAME size 7 hex nut ‘slips’ in both the top and bottom calliper release things (apologies, not sure of the proper name).
Really frustrating as the original fix on the drivers side was simple to do.
Does anyone know of any tricks to sort this, and/ or have you had the same issue. Was starting the think BMW were playing a trick on me by putting slightly different sizes on the car!!!
I’ve tried a size 8, but too big.
Thanks in advance.
Jonathan
You can use Mole grips to remove the slide pins but you will need new rubber sleeves they slide in as you will need to cut them away to get the grips on the pins. If you do this and need new parts , I have some you can have if you send me a PM.
ps. If you're close enough to me I can help you do this here.
Miffysmith
Hi Tony
Thank you VERY much for your kind offer. Pleased to report all sorted. Found a 7.5 standard Allen key and with some wellie, got the pins out. Cleaned the pins, regreased and replaced. Took The Lady for a quick spin and all feels/ sounds great.
Once again, thanks for your help… and as a novice mechanic, watch out for my future requests for help 😂
Cheers
Jonathan
Hi Tony
Cheers
Jonathan
Hi Jonathan, happy to hear you have got the job done now. Offer always good.
