- Joined
- Apr 27, 2012
- Points
- 100
First off Merry Xmas to all the members who celebrate Xmas...
Below is a pic of the first fitted prototype of a non M gearshift surround. I will be having moulds made in the new year and getting them chromed or finished in a brushed aluminium finish. They are easy to fit and requires no drilling, cutting etc which will damage the OEM status of your cars.
The pic below is the result of several trials which finally resulted in this solution. As you will see if you look at the relative facia in your cars, there is literally 2.5mm between the hole for the window switches and the hole into which the gearshift boot is fitted. This was been the main problem to overcome and still to provide a stable and well fitted gearshift boot trim
