new to z3
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
Hello and :welcome:.
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
Hello from Canada and welcome to the madhouse!! Enjoy the car the forum and all the crazies that reside here!! JIM
Gundun
Belgian Zeds
West Flanders
2.2i Sport Line Individual
Hello and Welcome from the EU :D
If you have never driven a RWD don't rush it: the Z3 is a lady that wants you to take your time with it, or you might get spanked ;)
shaunsas
I put 18" wheels on and admittedly the wrong profile tyres..45s . Going to change them to 30s , will this stop the slight rubbing of inner arch when in a slight adverse camber ?
Antm72
South Yorkshire
I imagine so i thought when i looked at the pic that is was possibly on 19's
Im on 18's
Wheels are 8.5j and 9.5 j i have 225/40/18 front
And 255/35/18 rear.
The height of the tyre may be causing it an issue as the profile may be causing the rubbing, normally there is room what are the wheels widths and offsets do you know ?
shaunsas
Im on 18's
And 255/35/18 rear.
They are 8.5 on the front and 9 on the back 225 and 255 rear , put straight on
Antm72
South Yorkshire
Is it the front thats rubbing ? Are the wheels flush to arch ?
Sounds like tyre profile its about 13mm larger over all than stock so its probably your issue
shaunsas
No it's the rear rubbing, could it also be a combination of the springs being old and spongy?
Antm72
South Yorkshire
You just have too much tyre in the arch i think its about 15mm bigger to the rear .
If its lowered and the dampers are not great it will possibly catch at the rear of the back wheels as the liner kicks out slightly as it gets near the bumper.
Mines was lowered 40mm odd and caught abit on the correct tyres.
The springs shouldn't be causing it unless they are laz. Its more like the dampers arn't damping, alot of zeds are still on their original dampers no leaks but when removed have no rebound at all and this could be making the back end feel alittle loose.
With the tyres being wrong it may be catching more than it would if the dampers where more efficient.
3 bolts remove the rear dampers one at the bottom and two up top It may be worth checking how they are by removing one.
shaunsas
Thanks that's a great help
