NEW ROOF (SOFT TOP)
Discussion in 'Z3 Roadster & Coupé' started by FRANKIE, Oct 24, 2014.
  1. FRANKIE
    FRANKIE Zorg Guru (V)
    American Zeds The M44 Massive
    Sep 2, 2013
    5,264
    3,398
    187
    Model of Z:
    Has anyone ever installed their own new (replacement) soft top?
  2. badman gee
    badman gee Guest
    As discussed 5 mins ago, not me!
    I've seen it done and in too scared!
    • Like Like x 1
  3. hard top
    hard top Zorg Expert (I)
    Dutch Zeds The M44 Massive
    20,766
    6,050
    213
    Netherlands
    Would not even want to try Frankie.
  4. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,137
    9,217
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    @Lee switched the hoods on his. He might give you a better idea of what's involved :)
  5. Rudyrov
    Rudyrov Zorg Legend
    Jan 29, 2014
    214
    104
    69
    Bothell, Washington
    Model of Z:
    2.8 L Roadster
    • Thank You! Thank You! x 1
  6. FRANKIE
    Sep 2, 2013
    5,264
    3,398
    187
    Model of Z:
    • Like Like x 1
    • Agree Agree x 1
  7. hard top
    20,766
    6,050
    213
    Netherlands
    Well if you do Frankie, please take some pics when you do and may be a write up?
    • Like Like x 1
  8. Lee
    Lee Zorg Guru (V)
    British Zeds #ZedShed M Power
    Mar 26, 2014
    2,885
    3,611
    187
    Model of Z:
    Z4 Coupe
    I did a soft top swap on my other zed, relatively easy. I brought the sealing compound in a real, remove the 18 screws along the inside (below the window. Disconnect the motor arm (pop a pin and the joint comes apart) then remove the 3 bolts on each side. give it all a good shake to break the old sealant and lift. Took longer to clean the old sealant off. took me around 3 hours.
    • Like Like x 3
  9. FRANKIE
    Sep 2, 2013
    5,264
    3,398
    187
    Model of Z:
    What did you use to clean the old sealant?
  10. Lee
    Lee Zorg Guru (V)
    Mar 26, 2014
    2,885
    3,611
    187
    Model of Z:
    Z4 Coupe
    I have some wipes from where i work that contain alcohol. (Azo wipes) Great for cleaning surfaces.
  11. hard top
    20,766
    6,050
    213
    Netherlands
    Bad Boy uses those. Doctors orders.....
    • Funny Funny x 2
  12. FRANKIE
    Sep 2, 2013
    5,264
    3,398
    187
    Model of Z:
    Your quote: I brought the sealing compound in a real..
    Don't quite follow that, and its something I'm concerned about. Could you explain that again. Thanks. Frankie
  13. t-tony
    t-tony Zorg Expert (I)
    Supporter British Zeds
    30,742
    14,487
    220
    Model of Z:
    Z4 3.0 Auto
    Frankie, I'm sure that Lee meant a reel of sealant which would come on a non sticky backing tape where you would apply the sealant to the area required then remove the backing tape to leave the sealant in situ. Hope that makes sense.
    • Agree Agree x 1
  14. vintage42
    vintage42 Dedicated Member
    Dec 24, 2013
    227
    66
    39
  15. Lee
    Lee Zorg Guru (V)
    Mar 26, 2014
    2,885
    3,611
    187
    Model of Z:
    Z4 Coupe
    Exactly what tony said. The harder way of sealing the roof was with a tube of sealant which gets messy.
    This reel of sealant is the same stuff and easier to apply.
  16. FRANKIE
    Sep 2, 2013
    5,264
    3,398
    187
    Model of Z:
    Just got home from work. I'll eat, then start on the top. I'll take out the seats first.
  17. Brian4
    Brian4 Zorg Guru (IV)
    British Zeds East Anglian Crew
    Dec 23, 2011
    2,514
    2,004
    173
    Hinckley/Burbage
    Model of Z:
    Z3 3.0i Auto
    Don't forget once the seats are out don't turn on the ignition or the airbag light will come on, better still disconnect the battery as long as you have the radio code.
    PS Good luck
    • Agree Agree x 1
  18. FRANKIE
    Sep 2, 2013
    5,264
    3,398
    187
    Model of Z:
    My seats have some play in them and I think I must replace something,Bushings? while they're out.
  19. FRANKIE
    Sep 2, 2013
    5,264
    3,398
    187
    Model of Z:
    I saw a post about this on another forum some one sent me to about the top. Something about spacers. I'll have to look at it again.
  20. hard top
    20,766
    6,050
    213
    Netherlands
Share This Page
