If you take a pic of the failure notice @t-tony and @Stevo7682 are MOT Testers so will be able to advise. As an aside, do you use it much and was it warm when you went to the test centre? A good Italian Tune directly prior to a MOT can help.Hi thanks for the welcome
I’m looking for help with my car it’s just failed the mot on emissions not sure how to resolve the problem any help sooner helpful
Yes gave it a good fun before mot it gets used a fair bit new air filter new replacement center part of exhaust wit cats and new lambers its always smelt fumeyIf you take a pic of the failure notice @t-tony and @Stevo7682 are MOT Testers so will be able to advise. As an aside, do you use it much and was it warm when you went to the test centre? A good Italian Tune directly prior to a MOT can help.
Hi andfrom Surrey, you say it has always smelt a bit fumey, this is not typical I think you need to track down the cause of the smell as it is probably connected to the problem.
Hi TonyShow us the complete emissions failure sheet (assuming they gave you one, they should but some don't). You say it's 2.0, is that a six cylinder 1991cc 2 litre or a 4 cylinder 1.9?
Their emissions machine must store the results on its hard drive for Vosa inspection. They will be able to print a copy, as I said they should give you a copy at time of test, many don’t to save paper etc. On your failure sheet it will give a reason for failure anyway too. If you can PM me your reg. no. I can look on MOT history.
Hi thanks for the welcome ( you might be my most local to Cheltenham )Hi and welcome from me in Oxfordshire, don’t be shy to post some pics up.
