New member with problem
Mark 56
Hi All
I’m mark I own-a 97 1.9 Z3 The problem I have with it is that their is no spark at the plugs I know I’ve got fuel pressure in the rail
Plugs are also wet all electrical connections look fine on it test the only fault that comes up is abs main relay is faulty has anybody
Got any idea what could be wrong
Duncodin
Pontrhydyrun - in Crow Valley
M44 FrankenZed
Does it have some kind of imobilizer that cutting the ignition?
I must confess that I don't know how the original oem imobilizer works but I have seen aftermarket ones on some cars that just cut the supply to the coil.
Mark 56
Hi I believe their is a censor chip on ignition that reads the key but I’ve had this tested and been told it recognised the key I’ve noticed that when I crank the car the record doesn’t move not sure if it should
Thanks mark
Oddly Godly
dunstable
z3 2.8
Have you tried using a code reader. Even if the eml light on the dashboard isn't on it may pinpoint the problem
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
